replacing springs in hp500 >
Old 04-18-2004 | 06:44 AM
Default replacing springs in hp500
how can you replace the valve springs in a 2000 hp 500 without removing the exhaust, with the spring compressor i have you need to remove the exhaust.
also what is the best plugs and wires to use and where to get them.
thanks 32 thunder rick.
rssteiny is offline
Old 04-18-2004 | 09:23 AM
Do you have the springs? If not I have a new set for sale.
shawn is offline
Old 04-18-2004 | 10:34 AM
Are the springs that you have the Comp Cams 929-16? If so, how much?
thanks........
As far as removing them, i dunno, sorry... The exhaust really does get in the way...
Madmax is offline
Old 04-18-2004 | 11:10 AM
I bought them from Teague. These are new. Comp 929 springs, crane retainers 99961, locks are crane 99098 and I forgot the seal number. I started to replace the springs on my HP500s and after installing 8 springs, I found a bunch of broken ones so I stopped. My engine builder will use Isky springs, so I will not use these. One set is in an unopened box and the other set has 8 never installed and 8 that will be removed and sold with the set.
$350 takes everything and I will include shipping to the 48 states.
thanks
Shawn
shawn is offline
Old 04-18-2004 | 11:51 AM
SummerObsession's Avatar
As far as replacing w/o removing exhaust, look for an air fitting that you can screw into the spark plug hole, rotate cylinder until both valves are closed, plug the air in to hlod vales tight, and replace springs. Rotating to top of compression stroke when piston is at TDC iin the cylinder and compressing with air should work.
Never done this on marine motrs, but it will work.
Someone should have/make a kit. Snap-on or Mac perhaps?
I believe they make a spring removal tool that screws on the head as well.
SummerObsession is offline
Old 09-28-2015 | 03:13 PM
Old thread...
But I'm trying to do this too! Have 2 different spring compressors and neither is small enough. I have gil manifolds.
I thought this one would be idea, but too tall.
What do people use with leaving the heads and exhaust on?
http://www.summitracing.com/int/part...6784/overview/
Rambocj7 is offline
Old 09-28-2015 | 03:23 PM
Gordo's Avatar
Charter Member #94
It's MUCH easier to just remove the exhaust.
Also easier to retrieve that keeper that will fall down between the head and exhaust manifold.
trust me,
Abby-someone
Gordo is offline
Old 09-29-2015 | 06:53 AM
depending on the exhaust if you can get the exhaust done or not...mostly not going to work..
ezstriper is offline
Perfectmix
16
08-04-2005 11:24 AM
Perfectmix
8
03-23-2005 03:28 PM
GG33ZX
3
03-04-2004 09:15 PM
rssteiny
12
04-19-2003 06:41 PM
jbrauer
03-31-2002 10:27 AM
