Paint for Engine Bay >
Old 04-19-2004 | 08:42 AM
Bam Bam's Avatar
Default Paint for Engine Bay
What paint should one use in the engine bay? What do you need to do to prep the area being painted?
Bam Bam is offline
Old 04-19-2004 | 09:49 AM
p4-33's Avatar
I use Interlux BilgeKote. I like white as it is easier to spot leaks. Also, it doesn't require primer.
Scrape, sand, and then wipe down with something strong enough to remove any greasy film, yet evaporate completely dry. I use acetone, and have probably lost some braincells in the process. Good ventillation is a plus.
Have fun,
Brian
p4-33 is offline
Old 04-19-2004 | 05:01 PM
blue thunder's Avatar
I used bilgekote last year. Still looks good. Use a good grease cutter, scuff then brake clean. Also used charcoil respirator.
blue thunder is offline
Old 04-19-2004 | 05:04 PM
Here it is a year later. I did do some minor touchup but still going strong.
BT
Old 04-19-2004 | 08:48 PM
offthefront's Avatar
Nice ... what motors ? that Closed cooling ....that the standard setup ?
offthefront is offline
Old 04-20-2004 | 10:13 AM
Bam Bam's Avatar
Thanks for the info. Not looking forward to this job, but it looks like crap right now.
Bam Bam is offline
Old 04-20-2004 | 11:44 AM
Thanks offthefront. 468s and the closed cooling is aftermarket. Not sure of the brand, I just rerigged it a little for my use.
BT
Fenderjack
Detailing, Painting, & Fiberglass
10
05-11-2007 08:36 PM
ratman
09-10-2006 04:27 PM
Deltarat
2
08-03-2006 03:21 AM
chewy1955
1
11-10-2005 06:19 PM
Mark D
Fountain
1
05-04-2004 03:03 PM
