One cool riser, one warm riser... >
Old 04-19-2004 | 10:08 PM
Danny_Ocean
Default One cool riser, one warm riser...
454/330
Just installed new manifolds, risers, circulating pump and raw-water pump. Everything seems to be operating properly. Plenty of water pouring out both exhausts. Water temp reads OK.
However...one riser (starboard) runs cool to the touch, while the port riser runs "warm" to the touch (sorta fluctuates between warm & cool).
Is this normal? Causes?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 04-20-2004 | 05:22 AM
Iggy's Avatar
Similar quest been posted here before.
It seems that the water flow will vary at idle. Somtimes it will flow more on the left and other times it will flow on the right.
Path of least resistance??
I'd check the temp as you're running on plane. See if it's even then.
Iggy is offline
bcfountain
2
08-21-2008 07:01 PM
inthered
12-19-2007 07:09 PM
Whiteknuckle
7
02-20-2005 03:58 PM
TwoKs
8
06-16-2002 04:04 PM
Shorgasm
03-19-2002 07:32 PM
