Stereo through bolting >
Old 04-20-2004 | 01:36 PM
dkwestern's Avatar
Default Stereo through bolting
I bought a new stereo/mp3/CD headunit for the boat, but don't know how to through bolt it to the storage compartment. It has the sleeve with tabs on the back to bend up, but I am guessing that won't hold. it has little threaded holes on each side of the chassis marked "T" and "N/T" Are there brackets made to fit these that would accomodate through bolting or should I make a custom L bracket that attaches to these and goes up to the bulkhead? Any help is appreciated. Thanks Darren
dkwestern is offline
Old 04-20-2004 | 02:25 PM
FWK
The sleeve you are talking about will not hold. You will need to add a strap to the back of the radio and you should not have a problem.
Old 04-20-2004 | 02:31 PM
dkwestern's Avatar
Thanks FWK, I have a strap, will that hold? I wanted to throughbolt it somehow, but if the strap is all I need I should be alright I guess. Any other opinions?
Old 04-20-2004 | 02:54 PM
FWK
That should do it. try to make sure the support strap is fairly tight
jayhawk261
Superboat
12
04-17-2008 08:15 PM
Sonny Spectre 30
0
03-29-2006 08:12 PM
plumbers crack
02-04-2006 06:36 PM
BajaRunner
Baja
6
06-03-2005 06:54 PM
1 bad habit
Fountain
5
12-11-2002 04:16 PM
