Cool Fuel Cover??? >
Cool Fuel Cover???
Cool Fuel Cover???
Old 04-25-2004 | 08:33 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
Originally posted by ragtop409
Motor mount screw?
Do you mean the nut on top or below the big pin (bolt) so YES! dont just tighten the top nut down. Your motor is out of line.
If your talking about the bolts that go into the block, yes tighten them suckers up.
Rag's
The picture below shows the right side motor mount. The top nut was about 1/8 to 1/4" up. You can see the color change on the threads as to where it was. I also inspected the left hand side mount and this top nut is slightly loose. I have not touched this side yet, but in the second picture below you can see what I mean. Suggestions? What should I do? How can I align the motor again?
RIGHT HAND SIDE MOUNT
Blue by You is offline
Old 04-25-2004 | 08:36 PM
FIERCE ALLEGIANCE
Default MOTOR MOUNTS OUT OF WHACK!!!
Here's the left hand side. You can see the top nut is lose.
Old 04-26-2004 | 09:28 AM
obnoxus's Avatar
Charter Member #1171
Actually the top nut being nylock is the same. Since the locking tab isnt bent over, the lower nut screwed itself down. raise the lower nut ( would be easier if you can take weight off the motor with a lift ) and check your alignment. Then make sure the tabs are locked so it doesnt happen again.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Rage
0
05-06-2008 11:00 AM
gsmith9898
1
03-14-2007 01:27 PM
mjb
12
03-12-2006 05:49 PM
Rage
13
01-14-2006 05:53 AM
