kaama drives on V bottom
Originally posted by cuda
The drives articulate in all directions.
The rotation of the props... you are running counter rotating props.... correct?.........
You aren't running a reverse rotation engine are you ?
I can see your props turn in Cuda.... but how do they do that?.... do you have one engine that runs in the opposite direction? Like the way the old inboards used to do?... or is the difference in the prop rotation accomplished with a gear change?... and where is the gear change?....
This is my understanding: Surface drives like rocker to get the bow up because they do not have the ability to trim it up as well as a stern drive. The same thing thing applies to a stern drive if it is very high X dimension. This applies to non-stepped hulls.
Rag's
