kaama drives on V bottom >
Old 04-25-2004 | 12:11 PM
Reed Jensen's Avatar
Originally posted by jaf302
Both engines run the same direction, the rotation change is in the transmission. Paul
So... you have to get transmissions that can accomplish the rotational direction change.... I know on SSM's the prop rotation is accomplished in the drive itself. Same with Bravos... but Bravos don't have a trans.... just a slippery cone clutch...
Reed Jensen is offline
Old 04-25-2004 | 01:21 PM
cuda's Avatar
They have twin disc MG 502 transmissions. I assume it comes either way.
cuda is offline
Old 04-25-2004 | 01:42 PM
Cuda, look closely at your trans where the shift cables hook up and there different the way they hook up. Paul
jaf302 is offline
Old 04-25-2004 | 03:03 PM
Reed, regarding step hulls, I understand that they do not require as much bow lift to run fast since they have the steps. Therefor, rocker is not needed as much as it is in straight hull application.
This is only my understanding.
jody165 is offline
Old 04-26-2004 | 12:04 AM
Jody.... thanks for the input...
Old 04-28-2004 | 06:50 PM
novascarab
thanks for the talk on kaamas. i did not want to reconfigure & rerig my scarab if those drives didn't work well. this should be a blast!!!! i've heard a lot of horror stories that the kaamas don't work, i'm glad to hear all's good because i set up my transom to fit the kaamas.
Old 04-28-2004 | 07:08 PM
cuda's Avatar
If for some reason you decide not to use them, drop me a line. Also, if you need new boots for them, order them now! I called Archer yesterday. They won't have any for 8 weeks, I put my name on the waiting list.
cuda is offline
Old 04-29-2004 | 11:07 PM
Poorsche's Avatar
Check out my add in Classified--pair of Arenson ASD6's for sale--
Poorsche
www.boatmat.com
Poorsche is offline
Old 04-30-2004 | 07:14 AM
kaamacat's Avatar
Cuda...... The TD502 is a fully reversable tranny. So if you wanted to reverse the rotation you only need to play with the cable mount.
(fyi. On my cat I've got them spinning inwards)
AND IF THIS HELPS AT ALL............ I have a copy of the 1985/85 Options from Wellcraft if you were to order a boat........... The KAAMA package was offered on the 30Panther, 30ScarabII, 30ExcaliburCat, and 38KV.
Bob
kaamacat is offline
Old 05-08-2004 | 08:16 AM
novascarab
how well does the boat back up & maneuver w/ surface drives? what is the difference between arneson rocker plates & k planes?
