Installing Switchable Mufflers >
Old 04-27-2004 | 04:50 PM
Cool Installing Switchable Mufflers
Need some help installing Switchable Mufflers. I currently have twins in a thru hull and putting on 4.5 Teague’s. I need to know:
1) Best way to remove the 4inch exhausts hose
2) Best way to cut a larger opening & protect it from water (do I need to re-coat it with gel coat or just resin plus a primer?)
3) Wiring for the mufflers
Thanks,
Dennis
88_Liberator is offline
Old 04-27-2004 | 05:55 PM
I figured out #2 with the hole saw thread
Old 04-27-2004 | 07:45 PM
MnFastBoat's Avatar
Charter Member#157
Default Re: Installing Switchable Mufflers
Thanks,
Dennis
first off, great choice of mufflers
I love mine
what i did to remove mine, pull twist and pull some more
that is the old tips anyway My old tips pulled out of the transom.
they were a b!tch.
However, the teagues go from the inside out. Even harder going back on since the tips have to be installed BEFORE you can put hte hoses back on.
I used a rotorzip tool to widen up my outside ports due to hte extreme angle on my setup. The inside two I used a 4" to set inside along with the 4.5 mounted on top of it to start the holes. Got that tip from OSO also.
wiring was easy.
ground to the block
hot to hte soleniod. i used the one soleniod for both sets and put in an inline fuse from the battery.
do you have an unused switch in the dash?
I just reused my old silent choice switch.
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
NJgr8ful
Swap Shop
6
08-12-2008 10:40 AM
dkehzrd
03-22-2006 05:37 PM
dean campbell
03-25-2005 02:33 PM
Jassman
06-10-2004 12:33 PM
Kokopelli
7
12-04-2002 05:50 PM
