Transom rot... >
Transom rot...
Transom rot...
Old 04-28-2004 | 05:38 PM
Default Transom rot...
I found out today that our 1985 30 velocity has some serious transom rot. Am i to assume that the rear part of the stringers are going to be rotted as well? Anyone had to go through this before? Thanks for the help
cowisl is offline
Old 04-28-2004 | 09:20 PM
paradigm shift's Avatar
Only way to really tell is to check. It would not be unlikely to see some rot at the end of stringers though. Rough way to start the summer.
paradigm shift is offline
Old 04-28-2004 | 09:27 PM
SSComp's Avatar
Although I've not had to replace my transom, I've seen several done. I had major work done to mine over the winter (balsa work, forward engine compartment wall, total regel). They will most likely need to replace them anyway to get at the transom from the inside.
Shop around for the best value (price and quality). You'll get all ranges. You'll save a lot of money (about 1/2) if you strip the engine compartment bare and take off all the stuff hanging on the transom.
I did mine in one weekend.
SSComp is offline
Old 04-28-2004 | 10:02 PM
Audiofn's Avatar
Charter Member #232
It depends on how they made the boat. Only one way to find out
Jon
Put your best foot forward!
Audiofn is offline
Old 04-29-2004 | 01:56 PM
thanks for the help guys! Talk about timing..
cowisl is offline
Old 04-29-2004 | 03:47 PM
aero-offshore's Avatar
check out "rotted transon " tread here from a couple of days ago. Good stuff!
aero-offshore is offline
offshoreratboy
Detailing, Painting, & Fiberglass
134
06-26-2014 11:01 AM
justice
Cigarette
37
06-11-2008 05:24 AM
superwrench0166
10
10-01-2005 11:17 PM
phughes69
1
08-10-2005 05:34 AM
Courtholl
Pantera
0
08-08-2005 09:59 AM
