water temp?
Old 05-06-2004 | 11:40 AM
boat4life
Default water temp?
I have a 496ho with a whipple and my temp reads about 145 while running on plane, but when I go done to an idle it goes up to about 160 or 165 is this normal, I just had a new sea pump installed so I know it is not that, what could this be.
Old 05-06-2004 | 01:04 PM
offthefront's Avatar
I would think its just ALOT less water flowing a idle/low rpms .....should be ok ...my 2 cents ...
offthefront is offline
Old 05-06-2004 | 03:23 PM
mopower's Avatar
Toxic FORMULA
If it doesn't go any higher I wouldn't worry about it. After idling for a few minutes does it come down any? Don't forget , you still have heat built up from running
mopower is offline
Old 05-06-2004 | 05:55 PM
Mopower,
Thats what I was thinking, heatsoak. Maybe it would help to drill the T-stat as well. With my crossover set up I would see spike when coming off plane because it was actually running cooler then the T-stat would close due to being cool then spike just before opening.
Tim T.
BadDog is offline
Old 05-06-2004 | 06:04 PM
mopower's Avatar
Toxic FORMULA
BadDog,
My oil pressure does the same thing. 70 lb running , then 30/40 at idle. Lets it idle for 5 minutes and its back to 60 lb . Take off and 70 lb again.
A couple of 1/8 inch holes may help but may also lower your running temp too
mopower is offline
Mat Raymond
3
01-12-2009 01:13 AM
86formula242ls
05-23-2006 07:52 PM
MitchStellin
10-07-2005 06:48 PM
Pmpaint1
3
04-25-2005 11:10 AM
Mrgoodwrench
3
03-25-2002 11:43 PM
