Stereo Noise >
Stereo Noise
Stereo Noise
Old 05-10-2004 | 07:21 PM
Default Stereo Noise
FOR ALL OF YOU SOUND EXPERTS. JUST UPGRADED THE STEREO AND PUT IN 2 AMPS, ONE FOR THE SPEAKERS, ONE FOR THE SUBS. WHEN TRIMMING THE DRIVES OF K-PLANES, I GET A POPPING FROM THE SPEAKERS. NO OTHER ELECTRICAL DEVICE OR SWITCH INTERFERES. WHAT IS THE PROBLEM/SOLUTION?
KBUSH1 is offline
Old 05-10-2004 | 07:39 PM
Scott's Avatar
Charter Member #30
Default Re: Stereo Noise
Is the stereo that loud you have to shout when you ask a question (turn off the caps)
Turn off the stereo when you use the trim and the speakers will stop popping.
Just kidding the following link should help
noise search info on 12v.com
I have Steps & Bubbles!
Scott is offline
Old 05-10-2004 | 11:34 PM
go to "the12volt.com" I built my whole stereo system by asking questions on this sight, and it is awesome!!!!
justinVIP is offline
Old 05-11-2004 | 09:36 AM
FWK
You have a problem with your ground. Where did you ground the amps?
Old 05-12-2004 | 06:36 AM
both amps are ground to the same battery.
KBUSH1 is offline
Old 05-12-2004 | 06:47 AM
Audiofn's Avatar
Charter Member #232
You could also have a bad ground on your trim pump causeing this. Check for corroded cables and stuff like that.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-23-2004 | 10:00 AM
aTX427's Avatar
Audiofin, can you drop me an email? I would like to speak to you about some Babbs. [email protected]
aTX427 is offline
Maritime_Eng
4
07-31-2008 05:06 PM
razor1115
2
06-14-2007 09:34 AM
Lickitysplit
Powerplay
37
04-07-2007 06:11 PM
JIMB
0
06-20-2006 08:23 AM
johnlor
3
09-09-2005 12:18 AM
