Volts
Old 05-13-2004 | 06:06 PM
seahawk's Avatar
Default Volts
What is the max. voltage the alternator can put out to charge the battery before it is to much.
12
13
14
15
seahawk is offline
Old 05-13-2004 | 06:12 PM
shouldnt be more than 14.8v if voltage regulator is working correctly
gusman is offline
Old 05-13-2004 | 06:27 PM
seahawk's Avatar
I get 15v at the alt. and 14.5v at the battery is this ok.
seahawk is offline
Reed Jensen's Avatar
I've seen some alternators "spike" after a heavy load has been put on the battery... just a little over 15 volts... but that is rare...it is only for a few seconds and it has to be a big alternator. Normally they run about 13.5 to 14 max.
Reed Jensen is offline
Old 05-13-2004 | 06:28 PM
How long is the alternator putting out that voltage... just for a short time after starting the motor?... or is it that high all the time... even after running for a couple of hours?
Old 05-13-2004 | 06:30 PM
What kind of amperage is the battery getting? Have you tested that?
Old 05-13-2004 | 06:33 PM
seahawk's Avatar
I have'nt really noticed. I only checked it right after a start. Should it be less after running for a wile
seahawk is offline
Old 05-13-2004 | 06:34 PM
seahawk's Avatar
battery gets 14.5v when alt. is putting out 15v
seahawk is offline
Old 05-13-2004 | 06:43 PM
if the voltage at the batt is 14.5 it should be fine.
gusman is offline
Old 05-13-2004 | 07:32 PM
seahawk's Avatar
ttt
seahawk is offline
drpete3
16
10-05-2007 10:47 AM
482
1
04-13-2005 02:27 PM
velo
2
10-04-2004 12:42 PM
