Jetting?
Old 05-13-2004 | 06:44 PM
jryan26's Avatar
Default Jetting?
I have 540s with merlin intakes, and holley 800cfms. The carbs have the stock staggered jets. I am running the crane 741. Do any of you have a similiar set up? If so, what jets are you using? I was thinking of starting with 81/92. Thanks
jryan26 is offline
Old 05-13-2004 | 08:12 PM
Hp 500 509cu", Merlin intake, 800 holley & Crane 731 cam. Sea level 85/96 stock power vlave
Johno is offline
Old 05-13-2004 | 08:23 PM
jryan26's Avatar
Thanks Johno
How did you come up with that combo? Did you try several different jets? Thanks
jryan26 is offline
seahawk's Avatar
509/crane 731 cam merlin intake holley 830 w/ 93/93 jets 6.5 power valve
seahawk is offline
Old 05-13-2004 | 09:16 PM
johnnyboatman's Avatar
jryan
i thought a 540 needed a bigger cfm carb?
i have roller 502 w/ demons running 84/95
johnnyboatman is offline
Old 05-14-2004 | 05:36 PM
Modified zz 502,800 CFM 9022 carb.86 pr 96 sec 6.5 PV.A bit rich at idle but still working it back.No transom soot and plugs clean after a hard run.I am having a problem getting the plugs to color,but they dont look overheated.I was richer but noted speed improvment backing down to here.It still seems a bit rich by comparrison of what other people are running.I might experiment some more but I'm gettin tired of stinkin like gas and oil everytime I go boating.
HARRISONMIRAGE is offline
randy carlson
3
03-18-2008 07:07 AM
KCHOTBOAT
5
06-29-2006 02:02 PM
HARRISONMIRAGE
3
07-21-2004 09:20 PM
Excalibur
5
04-30-2004 03:07 PM
johnnyboatman
12
03-31-2004 09:28 PM
