Verifying Engine Hours >
Old 05-16-2004 | 10:41 AM
Charter Member #795
Default Verifying Engine Hours
How does one go about verifying engine hours on a set of 1999 500HP's (EFI)? Doesn't the computer chip store hours? What do you need to "read" this info?
Thanks!
ontheh2o is offline
Old 05-16-2004 | 10:52 AM
Default Re: Verifying Engine Hours
The Mercury DDT, any merc dealer should have one.
gusman is offline
Old 05-16-2004 | 09:23 PM
mcollinstn's Avatar
Hours "follow" the ECU.
If the ECU's have been replaced or swapped with a low hour ECU, then the reading won't tell you squat.
If you have reason to question the reading then you should do a full leakdown to assess the condition of the rings and valves. And a 500EFI can be in need of valvesprings in as little as 100 "spirited" hours and lifters in as few as 150 hours (easier running can extend those to 220/300 hours)
mcollinstn is offline
Old 05-17-2004 | 07:19 AM
Charter Member #795
What should I expect to pay to have a leakdown test done on a twin engine boat?
Thanks for the help!
ontheh2o is offline
ak
10
07-01-2008 03:43 PM
dyno
01-29-2008 09:09 PM
Perfectmix
10
03-18-2005 10:32 PM
RonB
5
03-24-2003 06:32 PM
Ricochet
11-04-2002 06:17 AM
