How to get fiberglass to shine
RE: Aqua
If you end up buying this stuff, I'm convinced it's ashes suspended in a soft putty
Make sure you have a spray bottle of water it drys as soon as you start to buff it. I ended up spreading some on the surface then spraying it down and then started buffing. Make sure you keep the wheel clean and then buff it off.
Great product
RE: Frenzy wax
The stuff cleans like you will not believe! I used it on my out-drives and tabs that had the muck on them from last season and was impressed on how it wiped the stuff right off. It is hands down the easiest wax I have ever used goes on/off as advertised.
Great Product
Using both of these products cut my spring prep time in half.
No I don't get paid by these people
just a guy that hates to buff and wax.
Make sure you have a spray bottle of water it drys as soon as you start to buff it. I ended up spreading some on the surface then spraying it down and then started buffing. Make sure you keep the wheel clean and then buff it off. Great product
RE: Frenzy wax
Great Product
I have Steps & Bubbles!
BadHabit.......... Go get some 3M FinesseIt-II (or III) which is really used as a final buff after a 1500wet sand. (almost like what you have). Use it with a right angle polisher at a low speed......... It will shine like glass. (its basically a super fine compound....... you cant even feel the stuff). It may take a few times, but is very VERY safe to use. (fyi, does not work with a random orbit all that well, as you need the speed)
Then apply whatever wax you choose to.
Bob
Bob
