Merc. MEIF3 module needed Can anyone help >
Old 05-21-2004 | 11:20 PM
Arrow Merc. MEFI3 module needed Can anyone help
I know this doesn't belong in this section but in need of some help. Someone has to have one of these that they aren't using? Hopefully. I have to have it reburned from Tyler Croc. Can anyone help?
Looking for a MEFI3 for a Merc 502 motor. Having a motor built and it seems at this time the ECU is bad. As of the short time frame till Mem Day. Need something quike. This the last thing that is needed. Can anyone help?
Russ
russ is offline
Old 05-22-2004 | 10:58 AM
SteveDavid's Avatar
Charter Member #1093
Default Re: Merc. MEIF3 module needed Can anyone help
Russ,
Give me a call at 954-980-2643. I have one that we use for dyno purposes. It originally came with a 2000 500 EFI but we've reprogrammed it a couple of times for dialing in Whipple Superchargers. You would definitely need Tyler to program it for your application. I can fedex on Monday if you like.
Steve David
SteveDavid is offline
Old 05-22-2004 | 11:17 AM
aTX427's Avatar
I have one as well if Steve's does not work out.
John 512-785-9549
aTX427 is offline
Old 05-22-2004 | 12:38 PM
We sent it back to Tyler for him to check for sure. Should no Mon. This has been reprogrammed once from Tyler. Shouldn't he have been able to tell if there was something wrong with it when he programmed it? I have no clue on this so I'm just asking.
Russ
russ is offline
shawn
08-06-2008 09:32 AM
fandango
Wanted
2
05-10-2008 05:08 AM
tomcei
11
09-13-2007 10:57 AM
Kidnova
1
05-04-2007 01:09 PM
fandango
03-06-2007 07:05 PM
