Bravo Hard shifting? >
Old 05-24-2004 | 07:08 PM
Raypanic's Avatar
Default Bravo Hard shifting?
I test drove a boat the otherday, After the Bravo 3 drives were warmed up after a short cruise I had a very hard time shifting into foward, reverse was a little easier. When they were cooler they shifted easier. What would this indicate?
Seems to me like it sould be a shifter fork cone problem and likely not shift cables. Any Ideas?
Ray
Raypanic is offline
Old 05-25-2004 | 09:14 AM
Raypanic's Avatar
Default Re: Bravo Hard shifting?
ttt????
Ray
Raypanic is offline
Old 05-25-2004 | 09:40 AM
Take the rear cover off check that there is grease on the detent assembly.Sometime if it is dry it shifts hard.
Dixie Doug is offline
Old 05-25-2004 | 12:56 PM
Cignificant's Avatar
I just went through the same thing, only with a standard Bravo. But it wouldn't shift at all...
First, I replaced the shifter cable going through the transom - that wasn't it.
Second, I replaced the outdrive (I have a spare) - that wasn't it.
Last, I replaced the helm cable. Bingo!
Keep in mind the whole time I was changing things I could shift gears by hand using the rear shift bracket. I think as pressure was put on the helm cable it would expand the cable inside the casing causing it to bind.
BTW - the boat is a 1990 model.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 05-25-2004 | 01:04 PM
Raypanic's Avatar
YES, That should work, disconnect the helm cable and see how it shifts then. THanks fo rthe tips, The detent spring and plunger could be a problem too.
Ray
Ray
Raypanic is offline
MnFastBoat
20
12-14-2008 07:18 PM
awsomethunder
Drives and Lower Units
20
06-04-2007 07:32 PM
awsomethunder
6
04-27-2007 12:38 PM
Kidnova
4
09-26-2004 07:36 PM
durbin
7
08-26-2004 07:27 AM
