Bravo I noise >
Bravo I noise
Bravo I noise
Old 05-26-2004 | 09:20 PM
LA3
Default Bravo I noise
My bravo I makes a lot of noise while boat is hooked up to hose. The noise increases as the rpms increase. Sounds like everything is moving and banging around but prop is not turning. Yes, in netural-so prop should not be spinning. is this normal? if not, then what is making the noise. Engine is a 454 magnum. 1994 bravo I.
LA3 is offline
Old 05-26-2004 | 09:29 PM
Payton's Avatar
Charter Member #927
Default Re: Bravo I noise
With the engine off, drive in nutral, spinn the prop by hand. Does it feel smooth?
Sounds like it is about to let go. Bearings may be bad or ujoints.
Payton is offline
Old 05-27-2004 | 01:16 AM
RedDog382's Avatar
This is not at all unusual for the Bravos. I would check the lube for discoloration, burnt smell, and metal shavings. Any of the above would be indicators of an impending failure.
RedDog382 is offline
Old 05-27-2004 | 02:33 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
If You Spin It In Nutral All You Will Be Feeling Is The Lower Gear Set. Your Uppers Are Connected To The Flyweel!!!!!! The Noise Is Comming From The Upper Set And They Do Make Some Noise.
WILDTHING TAZ is offline
Old 05-27-2004 | 06:01 PM
BlownBajaOnHavasu
may be a stupid question, but do you have the drive in a down position? if it is trimmed up too high while you are sitting on the trailer, you will hear a lot of noise from the u-joint at an awkward angle.
Old 05-27-2004 | 07:08 PM
It could Also be a bad gimbal bearing, listening with a stethoscope will help pinpoint the noise.
gusman is offline
Old 05-27-2004 | 09:40 PM
When my gimbal bearing (in a Brano 1) was going out, I couldn't hear the noise when it was on the trailer but could really hear it when it was in the water idling.
BajaBuddy is offline
cloudmaster_321
11
06-07-2021 08:57 AM
mtocrs1
4
04-18-2006 12:58 PM
502SCS
14
03-01-2005 06:46 AM
zog02
7
05-02-2004 05:05 PM
djm
6
06-07-2002 06:28 AM
