Torque twist/Prop twist problem >
Old 06-06-2004 | 08:34 AM
born2burn's Avatar
Default Re: Torque twist/Prop twist problem
ALSO my X-dimension is 3" in measured wrong when I came up with 5"
born2burn is offline
Old 06-06-2004 | 09:45 AM
CFD12's Avatar
I have a 25 Sunsation which is very similar in length and width to yours. It does have a small pad. I experience the same "lean" you describe when at cruise. It is very easily corrected with some tab (bennets).
CFD12 is offline
Old 06-06-2004 | 09:47 AM
Official OSO boat whore
If it's squirly with a lefty, then don't run it. They put the helm on the right to help counter the prop torque, so I can see how the boat would be unballanced with a lefty.
Cord is offline
Old 06-07-2004 | 08:19 AM
born2burn's Avatar
ttt
Old 06-07-2004 | 09:26 AM
muffman's Avatar
I have 26 corsa with 496HO and mine does the same thing I am spinning a 28 bravo. It lists to the port side when taking off with the drive trimmed down. When I get on plane and trim the drive up it levels out. I have some cheap bennett tabs on it and it if i feel like using them I can keep the boat from doing it. I Know the feeling though my wife hates it she thinks the boat is going to flip over and all my reassurance doesn't help any. If you have 2 batteries you might try putting them both on the starboard side in the back. This will help some other wise the trim tab thing should work but for me its a pain in the ass to take off with the port tab all the way down. If you don't get it up at the right time the boat will list to starboard side even worse. I think If I had some better tabs it would be easier. I have just come to live with it.
muffman is offline
bernm3
1
06-16-2006 11:03 AM
formula1
02-10-2005 02:21 PM
PhantomChaos
05-21-2004 06:21 PM
