Torque specs for Bravo >
Old 06-05-2004 | 06:01 PM
Default Torque specs for Bravo
Looking for the torque spec on the propshaft bearing/carrier retainer nut on an XZ Bravo. Anyone know? Thx in advance.
azlineman is offline
Old 06-06-2004 | 10:12 AM
Default Re: Torque specs for Bravo
Bump
Old 06-06-2004 | 12:39 PM
Mr Gadgets's Avatar
Charter Member #601
azlineman,
You cant just torque the retainer nut. You tighten it to set bearing preload on the prop shaft. Using a new crush sleeve, you tighten till you measure 8-12 in/lbs with new bearings and 5-8 in/lbs with used bearings. If you tighten too much, then a new crush sleeve is needed. You can cheat and use a shim from the old style cases (1988) and setup proceedure, but it is easier to just buy a new crush sleeve. Merc calls them load rings. PN 67440T...
Happy to answer any other questions, may be easier to email me or pm me..
Dick
Mr Gadgets is offline
KCHOTBOAT
4
08-02-2005 06:21 AM
East Coast B
2
04-16-2005 11:49 AM
Harper220
3
04-14-2005 03:18 PM
CN24
0
03-28-2005 07:53 PM
dyno
6
07-11-2002 11:25 PM
