Help!
Old 06-07-2004 | 11:43 AM
bikinilover's Avatar
Default Help!
I dripped superglue on my gelcoat and I can't get it off. I tried laquer thinner and no luck. I didn't want to rub laquer thinner on there to lang as for fear of screwing it up. Any suggestions??
bikinilover is offline
Old 06-07-2004 | 11:51 AM
Wally's Avatar
Were doomed!
Default Re: Help!
if you have a good coat of wax on the baot then you should be able to just take a small flat head screwdriver and "tap" it off the gel. Hit the glue part not the gel and do it shallow in reguards to the gel surface. Other then that i cant be of any service
-Wally
Wally is offline
Old 06-07-2004 | 12:02 PM
Bill272's Avatar
Default Re: Help!
I think straight acetone will cut through superglue and normally doesn't harm fiberglass or gel. Paint is another issue...
Bill272 is offline
Old 06-07-2004 | 12:05 PM
Default Re: Help!
take a trip up to the hooby store...they make debonding stuff!!!
http://www.hobby-lobby.com/adhesive.htm
audacity is offline
Old 06-07-2004 | 12:11 PM
Official OSO boat whore
Default Re: Help!
I'd try acetone.
Cord is offline
Old 06-07-2004 | 12:16 PM
Default Re: Help!
o, go ahead and put a bunch of other chemicals on there...it most likely will discolor it as well as your gel coat (yellowish). then after you get it off use metal compound to remove the discolor....flitz works the best.
audacity is offline
Old 06-07-2004 | 12:20 PM
muffman's Avatar
Default Re: Help!
There is a super glue remover for those people that get their fingers stuck together.
muffman is offline
