Bleeding disc brakes >
Old 06-09-2004 | 01:46 PM
muffman's Avatar
Default Re: Bleeding disc brakes
All these creative methods will work just fine. I use a syringe with a small vacume line on the end. Fill it up with fluid, open the bleeder and inject the fluid in. If you hold the syringe vertical you can also suck the fluid from the master cyl. You can pick one up from your local pharmacy. Mine is about 3/4 in diameter and 6" long. It should cost less than 5$
muffman is offline
augie58
6
04-07-2008 10:01 AM
t500hps
25
08-16-2005 09:05 PM
sgr
2
08-17-2004 04:17 PM
DJD
11-28-2002 08:24 PM
Advantage_Rob
07-10-2002 10:11 AM
