Solid lifter Question >
Old 06-08-2004 | 09:03 PM
Scarab28's Avatar
Default Solid lifter Question
How often do you guys adjust your solid lifters (Non roller cam)?
Scarab28 is offline
Old 06-08-2004 | 11:51 PM
Reed Jensen's Avatar
Default Re: Solid lifter Question
It depends... iron block? or alloy block?... iron heads? alloy heads?... Roller rockers? or standard ball.... what ratio... what material are the valves? What are the original clearances?...... If this is an engine that you have built... the best thing to do is run it for a few hours and see if the adjustment has changed... Say ,.... run it 20 hrs... check... no change in clearance... then run it 40 hrs and check... no change in clearance?... run it 60 or 80.... If the valves are good material... and all the components are high quality... you theoretically should be able to run the engine for several hundred hours before they * might * need adjustment.
Reed Jensen is offline
Old 06-09-2004 | 12:05 AM
robyw1's Avatar
make it a habbit to check and adjust when ever performing a tune-up.
Roby
robyw1 is offline
Old 06-09-2004 | 05:19 AM
Iggy's Avatar
Used to have a street car with solid lifters. Spent every Saturday morning under the hood adjusting the valves. But then I drove the piss out of it too, lots of street racing.
Thre's nothjing like the sound a solid cam.
Iggy is offline
DonziChick
Prop Talk
2
07-14-2008 04:13 PM
ghittner
19
05-14-2007 05:36 PM
jeff1000man
04-18-2007 09:19 AM
Smitty
6
03-22-2005 03:06 AM
bob
1
05-27-2002 11:26 PM
