Standard or high volume oil pump >
Old 06-23-2004 | 05:56 PM
kmiller's Avatar
Default Standard or high volume oil pump
I have a 350. I bought a new pan and pump / Steph's eng. they said in a boat I should run a standard vol oil pump, so thats what I ordered. My dad said to run a high vol and thats what was in the motor. I never ran the boat so not sure how the old pump was.. They both have different welded on pick-ups, but I think I can swap the top on the pumps and use either pump with the new pick-up. whats your thoughts.....
kmiller is offline
Old 06-23-2004 | 06:27 PM
mopower's Avatar
Toxic FORMULA
Default Re: Standard or high volume oil pump
Be sure youu have proper clearance between the pickup and the pan with whatever combo. you use. Also I wouldn't use a high volume pump with a standard pan as they have been known to pump them dry at higher rpms. I have HV pumps but also have 10 qt pans
mopower is offline
Old 06-23-2004 | 06:45 PM
kmiller's Avatar
New pan I have is 6-7 quarts. Does that change any thing.
kmiller is offline
Old 06-23-2004 | 07:57 PM
mopower's Avatar
Toxic FORMULA
It looks pretty deep. Make sure the pickup is about a quarter inch from the bottom of the pan. Too far away and you run the risk of running out of oil...too close and it can restrict the flow . If you bought the pan , oil pump and p/u at the same time , same place hopefully they match.
mopower is offline
DORaymond
16
09-09-2006 06:30 PM
blue thunder
34
12-22-2004 12:57 AM
FlyFast
4
08-09-2004 11:52 AM
dyno
18
04-25-2002 10:24 PM
27 FOUNTAIN
12
01-18-2002 07:25 PM
