Dynos problems persist.....
Originally Posted by aero-offshore
I had the same problem, drove me to drinking, it was the bolt hole where the accessories bolt to just in front of the fuel pump cavity on the front of the engine block. That hole is machined all the way to the fuel push rod. Put in a bolt with sealant and wa la no leak!!! Make sure the bolt isn't to long or it will bind the push rod.
If your boat has a sail do you ride a horse to the ramp?
yes, I believe that hole goes all the way through on your motor, but It wouldn't leak that much, nor would the frt seal(sorry I didn't read that 1qt.=30sec. earlier) and the oil plug would have leaked from day 1. If nothin else We have oil additive that glows very well under blacklight here. Sray off the oil with brakeclean add it to the oil, fire it for a couple sec. then get in there with a blacklight. I'd gladly fed ex you a bottle of the stuff.
I'm familiar with the die I had an issue last year with a rear main that leaked and went that route....it never showed up till I pulled the seal, it had a tear right at 12:00 never showed up til the boat was bow high!!!!!
Ian the cooler is on the side that could be but then why didnt it leak on the floor?????ARrrrrrrGGGGGGGGGGG
Dyno, I just remembered you said this was gen 5 motor. Did you use a mark 4 timing cover? The bolt pattern is the same but the sealing surface is different. The gen 5 has a large u shaped gasket suface where the mark 4 is flat.
Ian I'm not sure it was a cover that I had laying around...what about crankcase ventilation? I put push in breathers in place of the hose to the spark arresters that the 420's come with....
