Dynos problems persist.....
#51
Even if your running a supercharger, you shouldn't have problems with excessive pressure in the crankcase with two breathers. If it still blows oil out of the dipstick, you have real internal engine problems. I'll give credit to the guy that built my engines, Lenny, at Millenium Marine for doing a great bore and hone job. There is never any noticable blowby at all. Just my .02
#52
Dyno,
Their is no way you could have put a gen 4 cover on a gen 5 and bolted the pan on and not said " something is ucking wrong here". It would be my venture of a guess that a line has come loose somewhere to pump that much oil that quickly.
Chris
Chris
#54
mystery solved I hope.....found a pin hole in the oil line to the remote filter must have pinched it on install or brushed a belt....I replaced the seal to be sure....filled and fired it ran it long enough to find out for sure, wow it can blow some oil in a short time.....Thanks for all the advice you guys rock!!!!
If your boat has a sail do you ride a horse to the ramp?
#55
Dyno-- Glad everything worked out for you. Thanks for telling us what the problem was. Some of these threads get real interesting and then all of a sudden the thread goes dead.--Lou
#57
the valcanized piece of rubber in the balancer is giving up the ghost put it on with a mallet one to many times I guess....I'm not taking the chance it it coming lose and going through the bottom of my boat. New one coming next day air from summit!!!
#58
Good job Dyno. We'll see you in Grand Haven. Just so you don't feel alone, I was in the bilge last night changing another starter. 548 ci. and timing locked at 35 just tears em up. Now I'm getting excited about Smoke.
draw it on with a bolt or you will damage the main trust bearings.
