Carb problems >
Carb problems
Carb problems
Old 07-07-2004 | 12:28 PM
Rookie's Avatar
Default Carb problems
When turning the engine over and not giving it any throttle gas just continuously spills into the intake until all fuel pressure has bled off. Took float bowl off and appears fine inside. Do I need to get a new needle and seat for the float?
Jason
Rookie is offline
Old 07-07-2004 | 12:41 PM
fo-shizzle's Avatar
Default Re: Carb problems
You are definately on the right track, needle and seat are first to change. Also, make sure float is adjusted to correct height.
fo-shizzle is offline
Old 07-07-2004 | 01:20 PM
Iggy's Avatar
Make sure the float doesn't have gas inside it. Any liquid inside will cause the carb to flood the engine.
Are you running an electric pump?
If so, do you have a pressure regulator in line? Fuel pressure shouldn't be over 6 psi.
Iggy is offline
Old 07-07-2004 | 01:36 PM
Rookie's Avatar
Mechanical fuel pump on a sbc.
Rookie is offline
magnuman
0
08-15-2005 05:24 PM
RSBone
8
06-04-2004 06:23 AM
bwiencek
18
06-10-2002 12:47 PM
imq707s
11
05-31-2002 07:46 AM
BAD-HABIT
9
05-05-2002 05:56 PM
