Did I have a bad oil filter or worse?
Save yourself the headache and use a large pipe cutter or if you plan to cut the filter open every time, then buy a filter cutter from your local race car shop, they are not that pricey and they make the job very easy.
Dave
Dave
Originally Posted by Sydwayz
Napa Racing 1060R made by Wix Racing. I'll delve into it on my spare time next week.
The 1060R has a 61 micron rating and the 1060 gold has 26 or 28 micron rating the 1060 gold has 8 holes for oil to go through and the 1060R has only 6 holes at the top. The NAPA 1060 gold is a better filter
An A/C Duraguard made by GM is a 25 micron filter and it goes for about 5-6 bucks. It flows extremely well and traps like the best. It has fewer but larger holes which make a big difference. I think you had a flow problem and the bypass valve was sticking. I would switch to the A/C personally. All the Corvette guys I know of stick to this filter.
Fram: PH5, DG5
Purolator: L34631
Purolator Pure Oine: PL34631
AC: PF1218
Motorcraft: FL-12A
Napa: 1060 1060GOLD
Wix: 51060
Baldwin: B1428 (top rated)
K&N: HP3002
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mercruiser: 35-802885Q
Mobile 1: M1-302
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
Purolator: L34631
AC: PF1218
Motorcraft: FL-12A
Napa: 1060 1060GOLD
Wix: 51060
K&N: HP3002
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mobile 1: M1-302
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Thread a pipe thread hydraulic fitting in the filter then chuck it in the lathe by the fitting and part it off with a threading bit.Nice clean cut if you have machine shop acces.
Pure Energy
04-23-2002 10:32 PM
