Transom Inner/Outer Assembly Method >
Old 07-12-2004 | 02:34 PM
Default Transom Inner/Outer Assembly Method
Ok,
So I'm finally putting things back together on the transom of my project. What method are most people using to seal the transom outer to the transom. 1) Just the Merc gasket ? 2) Merc gasket and silicon? 3) Merc gasket and 5200? 4) Merc gasket and some other sealant? 5) Something completely different? Also, with either of these methods what are the torque specs on a #3/#4 transom stud configuration? Thanks for the help.
Lunatic Fringe is offline
Old 07-12-2004 | 03:27 PM
Zanie's Avatar
Default Re: Transom Inner/Outer Assembly Method
Are you talking bravo?
With the fat o-ring type seal?
Zanie is offline
Old 07-12-2004 | 06:12 PM
Nope, #4 Speedmasters. They have probably a 1/4" cork style gasket that sandwiches between the transom and the outer transom plate/gimbal housing.
Old 07-13-2004 | 08:52 AM
The gasket is "supposed" to be enough to seal it. But on old transoms with soft spots, warpage, etc you never know. So I use some generic silicon. 5200 is kind of overkill, it's almost impossible to get off if you ever have to remove it again.
I've got the torque specs at home for SSM. But 30 ft/lbs rings a bell.
If I can remember, I'll double check tonight.
Gary
Gary Anderson is offline
Old 07-13-2004 | 11:20 AM
J-Bonz's Avatar
I agree 5200 is hard to clean off and work with. But, I have seen to many rotted transoms from using the cheap silicone or nothing at all. Go with the 5200, its burly and with stand many years in service
Good Luck,
Jack
J-Bonz is offline
Old 07-13-2004 | 11:37 AM
Official OSO boat whore
I'd use 4200 so they would be removable. 5200 is pretty much permanent.
Cord is offline
Bilgerat
Wanted
2
03-30-2008 10:03 AM
CcanDo
5
01-13-2008 09:17 PM
mcraymond3
6
03-16-2006 12:38 PM
jackhammer
6
03-21-2005 08:25 PM
