TRS lower gimbal pin/bearing-how hard? >
Old 03-13-2005 | 10:42 PM
Default Re: TRS lower gimbal pin/bearing-how hard?
Oops drove it out the bottom... did I hose it up?
jackhammer is offline
Old 03-13-2005 | 10:47 PM
Wow great tip insptech! That'll help with the next one...
Old 03-14-2005 | 01:00 AM
Mbam's Avatar
Offshoreonly Advertiser
Be careful not to break one of the ears, the ball joint press is perfect, but if the pin is locked in the top ear and you press the pin down the ear is going to try and bend until it hits the ring, there is usually about an 1/8 clearance. Heat helps big time, and tapping on the press while there is tension on it can shock it loose. Also is a good idea to wedge somthing between the top ear and the gimbal ring. Whatever you do, don't mushroom the pin. Just keep an eye on it to make sure it is moving in the top ear when it does start to move.
The top pin can also be a real pita to get out.
I hate doing that job!!
Mbam is offline
Old 03-14-2005 | 07:11 AM
Audiofn's Avatar
Charter Member #232
Inspect I used a bras drift, took out my grease fitting and drive the pin down from the top. Worked well for me. You have to be carefull when driving the pin out as there is a hole in the middle that the drift can get a little stuck in but you can just twist it out.
Jon
Put your best foot forward!
Audiofn is offline
Old 03-14-2005 | 08:33 AM
Ted G's Avatar
Oh man, thanks for reminding me Marc, I forgot to mention we put a socket in the gap between the ears to keep the top one from moving down. I guess as soon as you guys send me up my mystical adapter tool we ordered yesterday I will find out how hard the top pins are
I'm beginning to hate this job too
www.cbpba.com
Ted G is offline
Old 03-14-2005 | 08:40 AM
Audiofn's Avatar
Charter Member #232
See my PITA post above there Ted
Audiofn is offline
satisfactionII
5
10-24-2005 09:13 AM
DrNautica
10
03-31-2005 10:27 AM
Ran-Dom 32
22
03-24-2005 09:28 PM
CN24
4
01-15-2005 07:25 PM
batty
2
03-11-2004 10:54 AM
