Bravo One Repair
Charter Member # 430
Just got a call from my mechanic and after a quote (verbal) of a max $2,100 for repair of the upper end of the drive, he tells me that he found three teeth broken and the cost will be $3,000. I was told $2,100 was reasonable but coming back at $3k, I am questioning it.
I see rebuilts on the web for $3,500 and gear-sets for $300 or less.
Tips please. This is the first repair I have ever had to have done to my boat in four years!
I've seen alot of good drives from respectable OSO members here for sale for between 2500, and 3000.00 if it were me I'd wait and find one. Don't tell that to the mechanic though because he'll charge you extra .WTF.
That is what I thought. I just spoke to another mechanic whom I trust, he said that The parts were more like $12-1300 and the labor 7-8 hours. The original guy was quoting $1,000 just for labor! Double what my other connection was quoting.
Looks like I'll be out the door under $2k with the second guy, Campbell Boats of Havasu.
$3000 is entirely too much for a standard Bravo rebuild. $3900 well get you a brand new one(no trade) with warranty.
I bought one in 2002 for $3495 (new) from Marine Power Services in NJ.
The upper gears and clutches and new bearings and races that come with the update kit for and older Bravo last summer cost me $1100. You would also need the input gear so 12-1300 for parts. and I was charged 300 for aasembly. I had a clutch weld up so I didn't need both cases washed out like you would need. but I think $3000 is a bit much.
If you were to have all new beargings and gears and have it setup properly, then it could get that high. But th $1k for labor is a bit much..
There is reassemble and there is proper setup or blueprinting and proper shimming of the gears. If you have a light boat, small hp.. reassemble will be good enough. If you have power, it it recommended by all the upgrade people to setup the upper gears like the lowers are setup.. Merc's latest technique follows this theory..
Bravo Drives are not cheap to rebuild & with limited warranties afterward. Your best bet is to simply bolt on a new one & be done with it, in about an hours time. Sell the remaining good parts on OSO to help pay for the new one. They do have some value. I have a new, in the box, standard Bravo One Drive, 1.5:1 ratio, Full Mercruiser One Year Factory Warranty, available for $3,300.00. I can even work with you on the shipping cost. Give me a call, at home, @ 954-564-0751 anytime. Thanks, Ed
