mercury mech trim indicators >
Old 08-03-2004 | 03:06 PM
Question mercury mech trim indicators
i've just installed new trim indicators they work great. except when the drives are in the panel indicates 9 which is suppose to out when trimed out it moves to a lower # what did i do wrong the cabels can only be mounted from the bottom due to the restriction on the dash!
sonic28 is offline
Old 08-04-2004 | 05:17 AM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: mercury mech trim indicators
The #6 panel is opposite the rest, you will need a new lens. If it is a bottom entry panel, 9 should be at the bottom for all drives except a 6. At least this is true if using the conventional style actuators.
Mbam is offline
Old 08-04-2004 | 07:45 AM
hi marc
thank you i didnt realize you could chang the lens.do you know the part # its four position 2 drive 2 tabs
paul
sonic28 is offline
Old 08-04-2004 | 08:43 AM
Mbam's Avatar
Hi Paul, 844932 is white, 849516 is grey
Mbam is offline
Old 08-04-2004 | 09:08 AM
thank you mark
sonic28 is offline
skygod
07-18-2017 07:15 AM
crsmith
6
08-16-2006 07:50 PM
truckone
01-23-2006 12:47 PM
Audiofn
06-16-2002 09:49 AM
hauling ass-a
05-06-2002 01:35 PM
