-   -   Removing exhuast grime from the transom (https://www.offshoreonly.com/forums/general-q/84488-removing-exhuast-grime-transom.html)
INDY27 08-04-2004 06:22 AM
Re: Removing exhuast grime from the transom
waxing Frenzy cleans and waxes
cuda 08-04-2004 06:46 AM
Just be thankful the transom grime isn't on the bow.
97BossHammer 08-04-2004 07:13 AM
Yep....lack of wax causes that. Use a good cleaner wax to get it all off. Then just keep it waxed. Mine comes right off with a light solution of boat soap and a sponge.
I 2nd that. Here's what I found to be the easiest. I use simple green for the most part but as you mentioned you need something a little stronger to get the "stain" out of it. I wax my boat pretty often and mine runs a little rich on startup so I have the same type problem. If I don't wax the entire boat...I make sure to wax just the entire transom each trip. It'll save you some elbow grease and be a heck of a lot easier at the end of the day. As mentioned....all it takes is a damp towel and it'll come right off.
Outlawcowgirl 08-04-2004 12:43 PM
I am a true believer in Ring-Go but on the transom soot I have, it did not completely take it off. I have TERRIBLE transom soot on the Baja.Boat Shield works like a charm. You rub it on and you can see the soot coming right off. It goes on easy and comes off easy. It will also work on your rub rail and make it white like new. I have never seen my swim platform as white as it is after I use Boat Shield. I have noticed that it deflects the soot from forming too. It is a great product and you can order it from OSO. You should check it out!
performancemary 08-04-2004 09:18 PM
White Lightning takes it off easy . Also gets the white chock off the drives. For anything that still won't disolve use On AND OFF, BUT WEAR GLOVES.
frenzy 08-07-2004 09:21 AM
Waxing Frenzy! will not only remove the soot, it will make it easier to wipe off in the future; usually with just a damp rag.
wildthing357 08-07-2004 09:38 AM
Star brite black streak remover works great and won't remove the wax.
MAG502NUM 08-07-2004 12:54 PM
Soft Scrub W/ bleach.
HeavyChevSS 08-07-2004 08:32 PM
Have you tried Mr Clean Magic Eraser? - easy, non-corrosive and non- toxic. for harder stains on Fiberglass try Sno-Bol toilet cleaner but do not get on skin or painted surfaces Youch!
Turbojack 08-08-2004 08:55 PM
Vinegar, put in spray bottle. Spray on, wait a little bit then wipe off. It is also good for getting the Lake Travis water spots off.
