Mirage Plus/Bravo 1 to Hydromotive change >
Old 08-10-2004 | 08:50 AM
powerguy's Avatar
Default Mirage Plus/Bravo 1 to Hydromotive change
Yesterday went to swap out my mirage plus to a hydromotive prop. I had swapped out the mirage plus to a bravo 1 with no problem but when I put the hydromotive prop on the splines on the end of the prop shaft were about 1/8" to 1/4" past the back end of the prop. The thrust washer seems to be fine and fits perfectly. Do I need to use the old style mirage brass fitting on the end of the prop shaft to install these props?
"All I need are some tasty waves, a cool buzz and I'm fine"
powerguy is offline
Old 08-10-2004 | 09:47 AM
MnFastBoat's Avatar
Charter Member#157
Default Re: Mirage Plus/Bravo 1 to Hydromotive change
I found out at the Milwaukee races that Hydro props require a differnet brass fitting.
Very similar to Bravo, but just cut down real short.
You will have to get one.
I was told that you could possibly sue two thrust washer back to back but Iwould think this would be a little risky
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 08-10-2004 | 10:29 AM
powerguy's Avatar
I have two of the older style mercruiser parts to try. Hopefully that is it.
powerguy is offline
Old 08-10-2004 | 10:40 AM
Official OSO boat whore
No, this is a hydromotive specific part. If you had a way to accuratly cut it, the stock merc castle could be cut down to work.
Cord is offline
Old 08-10-2004 | 11:38 AM
powerguy's Avatar
Cord-
The merc castle looks like it would fit. How would it have to be cut down?
Dave
powerguy is offline
Old 08-10-2004 | 11:49 AM
Well, you said "older". I'm not familiar with any "older" style of castle nut. I only know the flo-torque style castles. The hydromotive castle is exactly like the current merc castle, but it has about a half inch of splines. If that description matches the "older" style of castle, then you are good to go.
Cord is offline
Old 08-10-2004 | 11:52 AM
powerguy's Avatar
Cord- that matches exactly what I have.Thanks.
powerguy is offline
JBoat
05-02-2008 02:16 PM
liquid asset
35
08-20-2006 08:08 PM
Oh Deere
Prop Talk
11
03-26-2006 07:39 AM
dtsquest
Prop Talk
12
04-21-2005 10:38 AM
Tejas Raz
2
06-26-2003 09:53 AM
