Push button ignition switches >
Old 08-14-2004 | 08:10 AM
ofshore's Avatar
Question Push button ignition switches
I want to replace my ignition switches and was wondering if anyone knows if there's a company that makes aftermarket ignition switches that have one key and two push buttons? I've seen them on different stuff but can't seem to find anyone who makes them.
ofshore is offline
Old 08-14-2004 | 08:46 AM
Strip Poker 388's Avatar
Rob
Default Re: Push button ignition switches
Try this . You can do a search on stock car products and look for the ones that cater to the dirt track .they usually do water proof
http://www.speedwaymotors.com/xq/asp...qx/product.htm
http://www.colemanracing.com/section/index.htp?id=256
this is a good company,,,http://www.daymotorsports.com/vendor/6/
These guys have a lot of stuff.high quality,,http://painlessperformance.com/togglecc.htm
here is a company that supply's a lot of Nasscar teams. Expensive$$.http://www.quickcar.net/ign_panels/ign_panels.html
Where the toggle switch is you can change over the a key switch .Make you on panel and paint it .All these company's sale just the parts
Rob
Strip Poker 388 is offline
Old 08-14-2004 | 08:49 AM
Official OSO boat whore
There is no reason why you couldn't use the stock key and add two push buttons. Boat US will have the parts you would need. The only getcha is that both engines will shut off at the same time.
Cord is offline
Old 08-14-2004 | 04:15 PM
mcollinstn's Avatar
You'll want separate shutoff switches for each. You can use a single key switch to turn on and off the main 12v bus to the switchgear for theft purposes, but you'll still want separate switches to turn the juice off to each engine's systems.
Either 3 position switches (down is off, center is on, up is start and is springloaded)
Or separate toggle switches for fuel pumps, ignitions and monitoring circuitry plus a pushbutton for the starter.
No real limit. It's just circuits. You can do whatever you want.
mcollinstn is offline
Old 08-16-2004 | 05:29 AM
ofshore's Avatar
Thanks for the info guys, I guess i'll have to make my own panel so i get exactly what i want, I didn't even think about seperate kill switches
ofshore is offline
plumbers crack
4
04-13-2008 07:30 PM
plumbers crack
Cigarette
9
04-10-2008 09:51 PM
waterboy222
06-06-2007 02:11 PM
damdonzi
03-06-2004 12:03 AM
masi242
05-02-2003 05:40 AM
