Prop advice/5 blade >
Prop advice/5 blade
Prop advice/5 blade
Old 08-31-2004 | 09:45 AM
Question Prop advice/5 blade
I have a 98 Fountain Fever 27 with a stock 502/415 mpi. Currently running the stock bravo 4 blade (I do not know what the specs are...as I am new to prop boats). At best it will run 68mph on the speedo at 5100. I am looking at 5 blades to get some better mid throttle cruise and not affect the top end. The only mods I have planned are new exhaust manifolds barring any major malfunctions. Any advise would be helpful.
evelkevin is offline
Old 09-02-2004 | 11:58 AM
HOUSTONPROP's Avatar
Default Re: Prop advice/5 blade
evilkevin, you currently have the best prop on your boat,The five blade will slow you down.It will give you nice cruising speed but your stock four blade can be labbed for addtional mid range speeds and addtional top end speeds,let me know if we can help out.
Darin
HOUSTONPROP is offline
Old 09-02-2004 | 12:20 PM
dido....your x-dim is too low...work your 4 blade.
audacity is offline
Inspector
Prop Talk
1
07-09-2007 07:50 AM
CA_Southpaw
American Offshore
13
11-06-2005 07:18 PM
NetGain
19
06-29-2004 08:32 PM
Perfectmix
08-04-2003 12:23 PM
Perfectmix
4
06-17-2003 11:26 AM
