EFI Gueru's
Old 08-31-2004 | 02:24 PM
IndianaHeat's Avatar
Default EFI Gueru's
can a Stock 502 Mag EFI system work "with no fuel pressure changes" On 502 HO Crate engine. using stock exhaust.
IndianaHeat is offline
Old 08-31-2004 | 04:11 PM
Default Re: EFI Gueru's
no one knows ?
tyler Crockett increased 2.5 #s on a 497 HP engine with stock ECU
Rich as these 502's run I guessing no. but was hoping someone has done this.
Old 08-31-2004 | 04:16 PM
robyw1's Avatar
what are the horsepower figures? I mean it will run it but if you have a lot more horsepower with your crate engines I will need to determine the BSFC to know if an EFI upgrade is needed. For the most part though yes it should work fine.
Roby
robyw1 is offline
Old 08-31-2004 | 04:31 PM
Duration @ .050" Lift Lobe
Int. Exh. Int. Exh. Centerline
211 230 .511" .540" 112
Old 08-31-2004 | 04:32 PM
450 hp at crank
Old 08-31-2004 | 05:48 PM
I believe that is just a stock 502 like the 502 Mag. The cam specs are a little different but I would think it should work just fine.
bobl is offline
Old 09-01-2004 | 05:43 AM
thanks guys will Do
Old 09-02-2004 | 01:35 AM
Registered User
is there Any way to boost fuel press?
kmhp is offline
Old 09-02-2004 | 01:49 AM
Registered User
is there any way to bump up fuel press on efi?
kmhp is offline
Old 09-03-2004 | 03:32 PM
replace the fuel regulator or buy a regulator top cap kit 25 psi- 60 psi adjustment cp performance , eddie marine.. etc. has them around 69- 70 bucks.
