Spindle replacement? >
Old 09-13-2004 | 09:15 AM
dyno's Avatar
Charter Member #655
Default Spindle replacement?
Well I tore up a spindle on my trailer this weekend are they a ***** to replace? Looks like a good welder could handle it.....never trashed one to the point of being replaced before.Anyone in West Michigan know where I can bring it to be replaced and about what should it cost?
Don
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 09-13-2004 | 10:21 AM
dyno's Avatar
Charter Member #655
Default Re: Spindle replacement?
ttt
dyno is offline
Old 09-13-2004 | 11:00 AM
rv
As you said it can be done with a person good at welding. The trick is to get the alignment correct so tire runs true. If not it will wear uneven and with bigger loads this will build heat in the tire and increase chances of blow out. A friend had this happen and he found it was almost as cheap just to replace the whole axle, it really wasn't that much.
Rick
rv is offline
Old 09-13-2004 | 11:26 AM
RedDog382's Avatar
Dyno,
I have asked technical assistance at Eagle about this and they pertty much told me the same thing Rick said ... replace the whole axle tube. I didn't ask a price, but supposedly not that much. Sorry I don't have a spare one of those laying around. Hope you're back together soon!
Chris
RedDog382 is offline
Old 09-13-2004 | 11:45 AM
I've done a couple of them in my driveway, no big deal. Cut off the old one, squared it up with simple hand tools, shimmed where needed, and welded away. No problems with either that I'm aware of.
JohnJan is offline
Old 09-13-2004 | 12:41 PM
dyno's Avatar
Charter Member #655
Come on Chris you have everything!!!!
dyno is offline
Old 09-13-2004 | 12:59 PM
merlin540
Thumbs up Re: Spindle replacement?
call the axle doctor they are nationwide and they will fix it anywhere anytime 1-800-472-3432 they did the spindle on my skater trailer when i was broke down in fla and i am pleased
Old 09-13-2004 | 02:43 PM
aero-offshore's Avatar
Dyno, get a spindle, a couple of beers and bring the trailer anytime.
aero-offshore is offline
Old 09-13-2004 | 04:06 PM
dlbCheckmate's Avatar
Or buy one at Wolfe's in BH they have a s**t load.
dlbCheckmate is offline
Old 09-14-2004 | 05:37 AM
dyno's Avatar
Charter Member #655
repair costs $140 with a new spindle cost of a new axle $170......buy the axel
dyno is offline
MegaByte*3
Outerlimits
11
06-05-2007 05:54 PM
duunoit
6
01-24-2007 08:33 AM
grimmy
05-04-2005 08:23 PM
dukenrock
4
04-16-2004 11:22 AM
JimmyBaja
15
01-09-2004 01:18 PM
