Valves Collide with Pistons ....
#31
Originally Posted by cig1988
Offthefront, as I said in one of my post. I have the 365 mag's and the aftermarket risers made no differance w/the old cam. As soon as I changed to a new cam (same spec) I had problems with water. It was plain to see with the bore scope I was having a problem with water in the exhaust. And yes, the stem of the valves were pretty rusty by just running the garden hose thru the engine. This was driving me up a f'in wall. The design of the riser was at fault.
#32
What are the valves? If not severe duty, and if engine is run out of tune (lean for instance) you can get this result. It will trick you because the exhaust valve will get hot and start to move, then start sucking water and then you get the result you have, or worse the valve head pops off. If its not that, then the risers most likely. Do you run the 3" spacers by chance? I could never keep that crappy system from leaking... terrible design.
This time put in top of the line manley valves for starters. Once running again, read the spark plugs in primary and secondary circuits of the carb. and determine state of tune.
BTW, all valves are stainless. But there is a large difference between high quality and regular grade, as wannabe was saying. You want one piece, severe duty, with no necking of the stem. Preferrably 3/8" stems.
BT
BT
#34
Actually, if the risers were leaking the water in the cylinders would cause severe damage due to increased compression and or hydrolock. The fact that no major damage is done indicates the valve is already bent before the water infiltration. Therefore the water is being freely pumped into and out of the cylinder via the bent exhaust valve. Your valves are weak and your tune suspect... (nothing personal
BT
)BT
#35
Blue Thunder/Cuda-- Good input on water ingestion/reversion and whether this Jasper long block contained marine components. But I'm still not hearing why a number of valves hit the pistons. I'm willing to bet you could open those valves to the point where there was coil bind and still not hit the pistons. Maybe the valve heads warped to the point where they weren't square to the valve stem? I apologize for sounding like a cynic but I'm just wondering if there's an automotive cam and valves in that motor. It definitely sounds like water is part of the problem cause or is the result of some other problem(s).
#36
By the way I dont take any of this personal so keep em commin ...mike ..
#37
Mike--Here's what I'd do. I'd put #5 at TDC, pull the spark plug and pump it up like I'm going to do a leakdown test. Then I'd remove the valve spring for the exhaust valve and replace it with a soft sring so you can check the clearance to the piston with the valve at it's normal maximum lift (you'll need a dial indicator). The results of this will hopefully explain why that exhaust valve has TWICE hit the piston. I agree that it's unlikely the timing gear/chain is the culprit with 25 hours but you have to check for everything. Who knows, maybe the keyway was broached wrong on the timing gear and the cam is way off (advaced/retarded). Now since we're concerned about water ingestion/reversion, did Jasper confirm that the cam is a Marine cam with appropriate Lobe Separation Angles to avoid reversion? I don't think with a Bravo setup that you should be extra vulnerable to your wake coming back up into your engine though the thought crossed my mind ( post #31 ) after you said it ran great on the hose until you took it out on the water. Which takes me back to confirming that you've got a Marine cam in that motor. Personally, I'm extra careful coming off plane. After making sure my wake doesn't catch up to me, I put both motors in neutral, bring the rpm's up to 1500-1800 to get a little water pressure to try to minimize any steam pockets,etc. Probably overkill but it's worked for me so far. Good luck! Lou
#38
If it's only #5 having the problem, did they check guide to stem clearance on that valve? If it's too tight, it could bind and cause the valve to hang open when it gets hot. I think the wrong cam or bad timing chain would affect all cylinders, not always #5. When you put the heads back on after the first repair, did you put them on the same sides you pulled them from? If so, concentrate on the head first. If you swapped sides and #5 went bad again then I'd look elsewhere.
Just my $.02
Just my $.02
#39
I have seen a several problems with valves hanging in apparently stock motors. It seems that there is always some water vapor in the area of the exhaust ports. It seems that it is very important to make sure that the exhaust gasket and exhaust manifold do not overlap any part of the exhaust port on the head. If it does it can cause any eddy of trapped water vapor that will dry out the oil film around the exhaust valves causing either accerated valve guide wear or seizure. We fought a similar problem with a 502 for months after replacing the exhaust with merc replacement. After trimming the gasket to match exhaust port and matching the exhaust manifold to gasket the problem never returned. Don't really know the science in this but it seems possible.
Mark
Mark
#40
Mike, just trying to help you out. I replaced the cam because it was worn, once the new cam was installed the reversion problem started. I only ran the engine in the driveway but had I ran the boat WOT in open water, I'm sure it would have been a simular problem to yours. It drove me nuts for weeks on end and with help from Marc @ BAM he helped to steer me in the right direction.
I wish I had a pic of the top of a merc riser to show you the differance. I can get a pic of the aftermarket riser if you want. Alot of good advice here on this thread for you to follow. Hope it all works out for you.
Stan
Stan
