Stroke, Blower, or Whipple
A hydraulic roller cam designed for the supercharged marine engine is a nice way to go. You can have the combustion chambers on the heads opened up to 130 cc and get that compression down. Use a good head gasket like the one from FelPro with the wire in the fire ring to seal those combustion chambers tight. I like to gap my top ring at .026 for that bore size so the ends don't butt from the heat. Ample fuel is a must, lines from the tank to the carb must be sized accordingly or a lean condition will occur. Get it right and you will be happy with the modifications.
Good Luck
Ed
Good Luck
Ed
