Hyd. Steering advice >
Old 11-08-2004 | 02:47 PM
Default Re: Hyd. Steering advice
I have a 30 Victory w/ twins and IMCO Hyd assist running off the Port pump. Who has advice for which company to go with to go full hyd/twin pump (I have the 2nd pump on the Star mtr already). Seems IMCO would be the logical choice since I already have their externals.
LHC30Victory is offline
Old 11-08-2004 | 03:15 PM
Minx20's Avatar
Question Re: Hyd. Steering advice
Originally Posted by monsta
minx, your system is regularly found on many hi-perf outboard set ups, like 28 skater's and such. strong , just harder. you'll need to buy a different helm. but if you have a capalano helm, save it there worth some pennies', if you decide to upgrade. if your boat runs 80+, i would suggest you add the rest of the component's to complete your system. i've seen to many bad thing's caused by ill-fated steering.
Thanks Monsta
Do I need a "capalano" helm, I have a Hynautic helm that is pictured below. Is this safe? I am trying to rig the boat for safety, and also trying to eliminate all the unnessasary items in the system. I want to make it simple but safe.
E.S.
Minx20 is offline
Old 11-08-2004 | 09:44 PM
T/O - Thanks.
Old 11-09-2004 | 06:31 AM
Dave M's Avatar
Veteran: Navy
Hey fred,
Do you carry IMCO products?
Dave M.
Dave M is offline
Old 11-09-2004 | 06:17 PM
monsta
Exclamation Re: Hyd. Steering advice
The capalano will do the job in my opinion, and you basically need 2 rams and the helm unit. Should probably use -8 hi-pressure hose, with chrome plated brass re-useable end's. I would still consider retro-fitting with full power. Just today i ran an 04' Gladiator that i just finished re-rigging, the p/s pump pulley was defective and let go. Then tried to finish our run a come in on manual steering , trust me not safe, acted like manual hydraulic, wich does not respond as fast as full hydraulic, no way , no how.
Old 11-09-2004 | 06:18 PM
monsta
LH< Dave m , we carry all major competitor's product's. Feel free to give me a call. 516-799-6029. If I can help ,I'd be glad to.
showtime83
0
06-04-2008 04:40 PM
Rage
14
10-10-2005 11:20 AM
cig28
0
05-07-2004 11:41 AM
cig28
2
05-07-2004 12:43 AM
cig28
0
05-05-2004 08:24 PM
