Hyd. Steering advice >
Old 09-28-2004 | 11:51 AM
Dave M's Avatar
Veteran: Navy
Default Hyd. Steering advice
I currently have a single ram add on system. I definitely want to go to a full system. Ideally I would want a dual ram full system.
Is a single ram full system that much of a safety improvement over the add on system? I am anticipating speeds in the 75-80 range. Completing my existing system would not cost that much. It would be a easy install too.
Maybe I could buy a single ram full system and request the dual ram helm unit, use my existing ram and have a dual ram full system?
What would you do?
Dave M is offline
Old 09-28-2004 | 12:53 PM
Default Re: Hyd. Steering advice
My understanding is that installing the entire system is the way to go. I rode in a 22 scarab just the other day that had the add on system and it seemed to have more play in it that a full system. It was a single ram, marine machine cable assist system.
I started from scratch and built the enitre system for mine. Its not cheap.
TxHawk is offline
Old 09-28-2004 | 01:48 PM
seabeach's Avatar
Look at XS Performance.... Brian will help you!
/Torbjorn
seabeach is offline
Old 09-28-2004 | 04:40 PM
articfriends's Avatar
depending on handling charateristics of your boat you should see improvement with full hyd over single extrernal. If your running a nosecone full hyd is mandatory (in my opinion). I pushed my mediocre handling boat (baja 272) to outright dangerous speeds (was 62 mph stock) and added twin ram hyd external imco to try to alleviate chinewalking,skipping etc around 75-78 mph,it helped but still felt loose and dangerous(no one unskilled could drive it). I drove it like that for 2 years,when i decided to juice it up further (540 w/8-10 psi boost),i started getting 82-85 mph out of it and handling was worse. I added the full helm this year and boat now drives straight and hardly ever chinewalks,Smitty
articfriends is offline
Old 09-29-2004 | 12:33 PM
Mr Gadgets's Avatar
Charter Member #601
As far as safety goes. When the gimble ring breaks at 83mph and you have one ram, the drive has a tendency to swing on that one ram. This puts the boat into a flat spin. It will go around maybe 2-3 times at that speed. I cant tell you much more because I was unconcious. Lucky I didnt get tossed out of the boat!!
Now at anything close to 80, I have both rams, full hydraulic steering and only the HP gimble.
So yes.. full Hydraulic steering.. a must!! for longevity!
Dick
Mr Gadgets is offline
Old 09-29-2004 | 01:07 PM
Dave M's Avatar
Veteran: Navy
Thanks guys,
I will probably bite the bullet and buy a full system. That leads to another question. I don't care for the way my ram is currently mounted outside of my k-plane. It might be a tight fit going inside the k-plane though. What is the minimum distance from the gimbal needed? Looking at IMCO's website I think the shortest system they have is 9.75", which I don't think I have.
Dave M is offline
Old 09-30-2004 | 10:32 AM
WildThing's Avatar
Dave if you call Brian Alfrey he can make a custom set up for you.
He can answer any questions you have about inside vs. outside set ups.
Brian will take good care of you & has the best bang for the buck anywhere.
It is an extremely heavy duty steering system that is priced right.
Several OSO member have his systems and rate these systems highly.
You can call Brian Alfrey at XS Performance direct anytime.
XS Performance Marine
Brian Alfrey
6688B Georgetown Lane
Middletown, Ohio 45042
1-513-737-0588
[email protected]
He goes by Alfster on OSO but he is rarely online.
However he always answers the phone.
http://www.xsperformancemarine.biz/
WildThing is offline
Old 10-01-2004 | 04:45 PM
Minx20's Avatar
Question Re: Hyd. Steering advice
Not to interupt your thread, but I had a question regarding this topic as well.
I know the difference between an "add-on" system and full system, but when I look at a Latham Marine catalog they have a section describing the difference of each type of set-up and I fall into a differnent category. I currently have a MM setup for my Bravo1 with dual rams. What I don't have is a power steering pump, overflow, filter, etc. My setup is a "self contained" hydraulic system. Other than the steering being more difficult, what are the pro or cons to my set-up? Is there a safety issue with what I have, or is it safer being that there are less items to break/leak between the rams and the helm.
Thanks for the info.
E.S.
Minx20 is offline
Old 11-03-2004 | 04:56 PM
Cmoney's Avatar
ttt
Cmoney is offline
Old 11-04-2004 | 08:14 PM
monsta
minx, your system is regularly found on many hi-perf outboard set ups, like 28 skater's and such. strong , just harder. you'll need to buy a different helm. but if you have a capalano helm, save it there worth some pennies', if you decide to upgrade. if your boat runs 80+, i would suggest you add the rest of the component's to complete your system. i've seen to many bad thing's caused by ill-fated steering.
