Winterizing-Alpha Drive Question >
Old 10-07-2004 | 06:11 PM
ChristianGott's Avatar
Default Re: Winterizing-Alpha Drive Question
When you split the lower...
1. Don't forget to replace the little, tiny gasket that seals the hole between the 2 halves that the gear oil flows through.
2. Be very careful reinstalling the "water tube". There is a rubber gromet at the top. It usually stays stuck in the upper, and when the lower is reinstalled, it is VERY EASY TO PINCH IT, which then restricts waterflow to the entire engine.
ChristianGott is offline
Old 10-07-2004 | 08:29 PM
HyperBaja's Avatar
Having everything in forward is key.
Yep.
And impellor is 100 hrs or 2 years, whichever comes first.
Really isnt necessary to pull it off for winter.
HyperBaja is offline
Old 10-08-2004 | 08:22 AM
remember if it's twins couter rotating starboard shift forward port all the way back.
sonic28 is offline
oreo11zeus
Do It Yourself, Boating on a Budget
9
04-23-2008 11:04 AM
David Stotz
10
07-02-2006 07:48 PM
rchevelle71
2
03-03-2004 04:19 PM
Raven
7
05-31-2003 07:56 PM
