Trolley to remove/refit B-1 drive >
Old 10-08-2004 | 10:46 AM
Wobble's Avatar
SORE MEMBER
Default Trolley to remove/refit B-1 drive
Anybody seen a deal on these things? I saw one at a boat shop, it lifted the drive to correct height and allowed one man install of drive. Between mine and my friends boats it would be a great tool to have.
Mark
Wobble is offline
Old 10-08-2004 | 09:52 PM
mcollinstn's Avatar
Default Re: Trolley to remove/refit B-1 drive
regular old motor hoist works real well. I've got a custom 4 point strap that hangs a drive level. Just pull it forward or reverse and it holds it at the right height.
I run across motor hoists for around $75 every so often.
mcollinstn is offline
Old 10-09-2004 | 02:38 AM
articfriends's Avatar
I seen one too at tyler crockets shop,looked like a floor jack built to put on drives,was going to try and make one from cheap jack from sams club but never did,Smitty
articfriends is offline
Old 10-09-2004 | 05:39 AM
Dave M's Avatar
Veteran: Navy
I built one. Not the prettiest thing but it works and only cost a few bucks. Do a search on "outdrive stand" and you will see some other options.
Attached Thumbnails Trolley to remove/refit B-1 drive-2004_0901_140419aa.jpg   Trolley to remove/refit B-1 drive-2004_0901_144401aa.jpg
Dave M is offline
Old 10-09-2004 | 10:59 AM
Viper31's Avatar
I used ideas from members of this board to create these projects. I took a $20 dollar 2 Ton Chinese jack and modified it with about $25 of steel and other materials. Also scabbed some wood together to make a stand to store the drives in.
Attached Thumbnails Trolley to remove/refit B-1 drive-drivejack.jpg   Trolley to remove/refit B-1 drive-img_0009.jpg
Viper31 is offline
Old 10-09-2004 | 11:03 AM
cougarman's Avatar
here's a link for you.
Boat lift
cougarman
cougarman is offline
Old 10-12-2004 | 09:59 AM
Wobble's Avatar
SORE MEMBER
Thanks Guys,
I have found a couple of others over the weekend.
http://www.kerrsmarine.com/html/sd3.html $775+ ship
http://www.bimsracingproducts.com/Outdrive%20Stands.htm $139.45 incl ship
this looks like the perfect one for the hobby guy. They say you can adjust height by raising/lowering trailer tongue. +made in USA
Mark
Wobble is offline
Old 10-12-2004 | 10:00 AM
Wobble's Avatar
SORE MEMBER
BTW I meant to give credit to cfm-techon SW for these links. Mark
Wobble is offline
Old 10-13-2004 | 12:51 AM
hillbilly24's Avatar
Mark,
I used to work at a boat shop and we had one of the tools you are reffering to the one made by kerrs is called the yard arm. it is the most annoying tool i have ever used and my coworker had the same opinion of it all it did was take up space in the corner. After you get the hang of putting a drive on by youself is not that difficult If you tell me what model drive you have i can run you through how to slam it on single handed.
hillbilly24 is offline
Old 10-13-2004 | 09:11 AM
Wobble's Avatar
SORE MEMBER
Originally Posted by hillbilly24
Mark,
Hillbilly
thanks for the info, I have installed and removed outdrive 6 times on my boat and 2x on my friends pachanga. Every time I do it I am afraid I will do my back again because of having to work under swim platform. I usualy have help but like to be able to jobs on my own if I want to.
I think I will get the bimsracing trolley. we pull all our outdrives at end of each year to lube and check alignment, at very least it will make good stand.
Mark
Wobble is offline
seamy
10-30-2008 06:53 PM
Froggystyle
Skater
55
04-16-2008 12:35 PM
bonecrusher
11-19-2007 05:23 PM
Maximus
04-07-2004 06:32 PM
