Carbbed 500HP fyel Pump >
Old 10-08-2004, 12:32 PM
Charter Member #139 /Moderator/Platinum Member
klaw's Avatar
Default Carbbed 500HP fyel Pump
anybody know the flow rate of these pumps my pressure drops below 5 at WOT I am going to try bigger line from tankand a Mechnical guage right at the carbs
klaw is offline
Old 10-08-2004, 01:00 PM
robyw1's Avatar
Default Re: Carbbed 500HP fyel Pump
In a carb application this is kind of tricky. Just because your FP drops doesn't necessarily mean you're leaning out right then. If you try a bigger fuel line then that would do nothing to increase pressure to your needle & seat. But you should use the biggest line that you can from tank to carbonator. If you use a return regulator (and you should) then both the feed line and the return line MUST be the same size.
Don't exceed 8-9PSI on the carb or the needle will be overcome and you will flood the engine. Keep in mind that with carbonator pressure is not needed as is volume.
Roby
robyw1 is offline
Old 10-08-2004, 03:38 PM
I am working through a fuel pressure issue with my new HP500 clone (OE Merc combo fuel/water pump)
At the carb I had 4psi at idle and 3 psi at WOT.
Replaced Carter pump BOTTOM with their strip pump bottom rated @ 7 to 8.5 psi/ 120 GPH ($64 @ Summitt). Merc fuel pump upper has a different lever.
New fuel pressure is 7psi @ idle Hope to test WOT over the weekend.
BTW; Holley Tech says 7psi max/ 5psi minimum for a 4150
RickR is offline
Old 10-08-2004, 03:41 PM
Have you replaced your fuel filter?????????????
BTW; I change my gear lube annually (200hrs) in my Merc belt driven fuel/water pump.
RickR is offline
Old 10-08-2004, 08:50 PM
Thunderstruck's Avatar
Is the pump old i.e. 2 years or so, if so, get a new pump and get 7-8 psi idle with 5-7 psig at WOT. Definitely stay above 2 psi at WOT w/ a stock 500 HP and >4 psig with a blower motor. My 500 HP carb fuel pumps have to be replaced on a regular basis. I recommend changing fuel pumps before changing fuel lines especially if the boat has been running with the same 500 HP motor for a while.
Thunderstruck is offline
Old 10-14-2004, 07:45 PM
klaw
After replacing the Lower on the fuel pump the pressure ended up being LOWER after a few minutes of run time. So I changed fuel filter and pressure continued to drop
Next step, I replaced the upper (diaphram). I'm back up to 7 psi at idle, hope to lake test this weekend.
To replace the upper, remove lever pin cap, drill a small hole in the other side of housing to remove lever pin with a punch. Then install Merc lever.
BTW OE pump had the same size check valves as the new Carter (M4889) Strip pump (Advertised 7 to 8.5 psi/120GPH)
RickR is offline
Old 10-14-2004, 08:00 PM
JCPERF's Avatar
CV products makes a replacement pump for the merc style.It puts out 130 gph @ 7-8 pounds.
JCPERF is offline
Old 10-14-2004, 08:56 PM
StrikinLightnin's Avatar
What size fitting connections?
How much?
StrikinLightnin is offline
Old 10-14-2004, 09:13 PM
JCPERF's Avatar
Inlet is #8 outlet is #10.I dont remember what I spent.It was around the time when I built my boat that I stopped asking prices on everything.I had Elephant ears for pockets in the end!
JCPERF is offline
Old 10-20-2004, 01:26 PM
klaw
On water testing WOT I ended up with 4.25 PSI. With Carter 4889 (arm changed)
JCPERF
Who sells CV products?
RickR is offline
BillR
11
07-29-2022 06:31 AM
HP500Hammer
15
01-30-2008 06:03 PM
jdub
7
03-26-2007 05:06 PM
klaw
10-08-2004 03:28 PM
Quick Reply: Carbbed 500HP fyel Pump
