Whipple Questions >
Whipple Questions
Whipple Questions
Old 10-16-2004 | 01:43 PM
Smitty's Avatar
Default Re: Whipple Questions
Hotlavey,
Looks like you have it all covered !!! Put some gas in and go !! Oh Yeah winters coming
Smitty is offline
Old 10-16-2004 | 02:17 PM
hotlavey's Avatar
Yep, it sucks. Just when I get all the problems solved.
The boats in storage now so that's it for this year. 05 is looking good.
hotlavey is offline
Old 10-23-2004 | 11:46 PM
Swede's Avatar
What do you guys think. I have a pair of 509's in a 30' Spectre and am thinking about adding the 3.3 carbed whipples. Right now I do not have a roller cam(Fairly large hydraulic cam). I have ported GM cast iron heads, 1050 dominators, speed pro pistons, crane roller-rockers, inconnel valves, 9:1Cr. Dynoed at 550hp at 5500.
I assume changing to a roller cam is probably a must? What cam would you recommend? Are the cast iron heads at 9:1cr ok with the whipple?
Swede is offline
Old 10-24-2004 | 08:29 AM
Smitty's Avatar
Swede,
You do not need a roller cam for a Whipple. Mine is on a stock motor with flat tappet cam. Call Whipple and ask for Dustin. He is the owner and will chat with you and tell you exactly what will work and what won't.
Smitty is offline
Old 10-27-2004 | 10:40 AM
Swede's Avatar
Originally Posted by sutphen30
what cam do you have now?
Edelbrock Performer RPM
adv(.006") 300/306 @ .05 240/246
Lift at Cam .330/.337 Lift at valve.560/.573
110 ICL
112 LSA
Flow test on my GM pocket ported heads.
.3 214/147
.4 269/184
.5 314/205
.6 340/220
.7 348/229
Swede is offline
Old 10-27-2004 | 11:36 AM
Bilgerat's Avatar
don't forget to talk with a few people who have had nothng but problems with them, then weed out owner error problems and system problems, I have seen long strings of posts on here with people complaining of their service, as well as people who are pleased, I know some people with them and some people who were happy to sell them and get them off the boat.
Bilgerat is offline
Old 10-28-2004 | 01:09 PM
hotlavey's Avatar
What is the best Whipple for my HP500EFI engine? I currently have the 2.3(2.2?). Should I consider the 3.3 or stay where I am? Dustin told me the smaller one is perfect for me and that the 3.3 is better for modified engines. I believe Pfaff says the 3.3 is the way to go.
Opinions?
hotlavey is offline
Old 10-28-2004 | 07:09 PM
Smitty's Avatar
I would trust what Dustin tells you. After all, he is the owner of the company. What would he gain by giving you wrong info???
Smitty is offline
Old 10-28-2004 | 10:00 PM
It is correct to use the 2.3 on a stock 502. If your engine is modified and breathes better on it's own, then you can use and need the larger capacity blower. this is better than spinning the small one faster. All positive displacement blowers are like this including Roots.
tomcat is offline
Old 10-28-2004 | 10:15 PM
GLH's Avatar
GLH
Craig,
If you want to go faster, take the patio furniture, the dinghy, the carport and the pool table off your boat!
GLH is offline
