Where do I get Pirelli Flooring >
Old 11-03-2004 | 07:21 PM
Default Re: Where do I get Pirelli Flooring
Why not do both, the pirelli style and a snap in over it? Mine is currently set up that way without the pirelli though, just studded fiberglass.
JPD Motorsports is offline
Old 11-03-2004 | 10:24 PM
Hey Panther,
Another place that you can find some flooring is Lonseal Inc.
It's just like Pirelli and they offer multiple styles. They also have flooring that is UV protected. www.lonseal.com
I have it in my boat and it works great.
Good luck,
Mike
Active Mike is offline
Old 11-04-2004 | 07:27 AM
Lonseal is the way to go. 6' wide & any length you want. Do a search on OSO & there is a wealth of info on this product. Discussed many times. Contact adhesive works better in the boat application as opposed to the epoxy they suppy.
John
Johno is offline
Old 11-04-2004 | 08:14 AM
rchevelle71's Avatar
John
Johno,
I have a section to do the floor in my Pantera, but it came with the boat, not sure if it is Pirelli, or Lonseal, I will ask Angel where he got it, so maybe I can get more. What is the thickness on the Lonseal, the stuff I have is only like 1/8" thick, for some reason, I thought it was thicker???
Rick
rchevelle71 is offline
Old 11-04-2004 | 09:32 AM
Stillcrazy
Lonseal is more cost effective and great people to deal with they will give the local distributor. Full sheet better than tiles and many different designs. Coin, Dot etc. they used to have a Marine page but I couldn't come up with it quick.
http://www.lonseal.com/gallery-main.html
Walt
Old 11-04-2004 | 11:08 AM
airshares's Avatar
What other adhesives can be used the to install the flooring? Is anything readily avail at home depot?
airshares is offline
Old 11-04-2004 | 03:16 PM
Panther's Avatar
Frank's Marine Service
Originally Posted by Active Mike
Hey Panther,
Good luck,
Mike
Thanks Mike, I'll check it out!!
Panther is offline
Old 11-04-2004 | 03:35 PM
Panther's Avatar
Here is the website with the Marine products. http://www.lonsealspecialty.com
I just got off the phone with the rep. and they have a much superior product for outdoors use (londeck coin), it is UV resistant.
Panther is offline
Old 11-05-2004 | 01:51 AM
ratman's Avatar
what did you cut it to fit with? how easy is it to trim? thx. ordering some in the am.
ratman is offline
Old 11-05-2004 | 10:13 PM
JnT's Avatar
JnT
We have a product similar to Pirelli on the boat I work on. Two coats of Mop-n-Glo wax and it looks awesome inside the cabin.Where sun hits it is fading fast after a year of abuse.Work boots and saltwater are not kind.Not sure of the brand but make sure your flooring won't fade before making the investment.
JnT is offline
