Help With Helm Pump >
Help With Helm Pump
Help With Helm Pump
Old 10-25-2004 | 06:08 PM
Question Help With Helm Pump
Hi All, I Just Got A 26' Seahawk With Single-ram Non Power Assisted Ext. Steering.the Problem Is The Helm Pump Is Making A Ratcheting Sound When Turned,and Sometimes Locks Up.i Have Bled The System And It Still Does The Same Thing.i Am Pretty Shure It Is A Bad Helm Pump,but Wanted To Get Some Advise On A Good Replacement With Tilt(displacement,and Approx.lock To Lock,price,sources)the Shaft Is 7/8" And Has A Throw Of 9",thanks
TINO160 is offline
Old 10-25-2004 | 06:32 PM
Ted G's Avatar
Default Re: Help With Helm Pump
They make rebuild kits for them, might be worth the effort to take it apart and look around in there, sounds like you may have a vane damaged.
www.cbpba.com
Ted G is offline
Old 10-28-2004 | 09:25 PM
monsta
imco makes a tilt helm. as far as the ratcheting alot of manual hydraulic helms do this. itys the desighn. the best manual helm is by far a capalano unit. 2 different models. displacement is the difference. about 650.00 .
sabercatt
Wanted
12
09-05-2008 07:40 PM
nocigarette
Wanted
3
01-24-2008 09:40 AM
TINO160
10-25-2004 05:52 PM
Stormrider
Pantera
9
05-31-2004 03:26 AM
Stormrider
05-26-2004 03:37 PM
