Sealand  Vacu flush >
Sealand Vacu flush
Sealand Vacu flush
Old 10-27-2004 | 06:28 AM
Default Sealand Vacu flush
Vacu flush toilet
The flushing water [ for wee only ] stopped making it to the toilet. Does the water come from the water holding tank or back at the pump itself, ther seems to be a little holding tank at the pump. Thanks in advance for any help Daryl
Daryl is offline
Old 10-27-2004 | 08:56 AM
Default Re: Sealand Vacu flush
Water comes from the pressurized drinking water system on the boat. Could be a bad valve. You might just want to unscew the whole valve assembly (connected to the side of the head by the foot pedal) and replace it.
Gary Anderson is offline
Old 10-27-2004 | 08:35 PM
mcollinstn's Avatar
Vacu Flush usually has drinking water plumbed to it thru the normal pressure system for the sink faucets, etc..
I've seen them plumbed with an impeller pump filling the unit with lake water, but that kind of negates the fresh smell benefit of using drinking water...
mcollinstn is offline
Old 10-28-2004 | 01:16 AM
Strip Poker 388's Avatar
Rob
Mine comes from the water tank, You can pull the lever up put extra water in it.May be stoped up with sediment from the water tank?
They have a pretty good manuel and parts diragahm that comes with it.i can copy it for ya or give ya the phone #;s if ya want?
Rob
Strip Poker 388 is offline
Old 10-28-2004 | 06:24 AM
Rob That sounds like the model I have the one with the handle. A copy of the owners manual would be great as I did not get one with the boat. I will not be able to check model # till this weekend. Thanks for your time !
Daryl is offline
Old 10-28-2004 | 08:29 AM
Rob
Pm me your fax # ,I will flush it to ya
Rob
Daryl
Fountain
9
03-04-2013 10:14 AM
BL6
08-14-2007 10:16 AM
Maritime_Eng
01-28-2007 08:40 AM
wrenchman
6
05-30-2006 09:04 AM
alter ego
7
08-16-2005 02:08 PM
