Distance between headers >
Old 11-01-2004 | 07:08 PM
38KV's Avatar
Default Re: Distance between headers
Originally Posted by caveman
38KV
What brand are those headers????
If you mean those in the link tomas posted in the first post,
I'm pretty sure they are GIL.
I had water injected GIL's on my ski boat back in the early -90's,
and they looked exactly the same.
If you mean my new water jacked headers, they are Bassett.
38KV is offline
Old 11-02-2004 | 12:56 AM
tomas_wallin's Avatar
Nice to see that Sweden rules - for once...
I don't know of what brand the headers are, all I know is that they are for BB and used to be on a skiboat.
Is it impossible to use watersprayed headers in a enclosed engine compartment? Not even if I use higher waterpressure etc to the connections.
I assume that the problem is the high temperature?!
I bought them from a guy in Stockholm
Thanks,
Tomas
tomas_wallin is offline
Old 11-02-2004 | 01:45 AM
I'm still considering the gold/platinum memberships, and I hate not to be able to open pics...
Can you email them to me too?!
[email protected]
How much did you pay for the Bassetts?
Perhaps someone know where I can find a set of water jacket headers, most preferably used ones...
Old 11-02-2004 | 06:36 AM
38KV's Avatar
It is not just the heat that is a problem. Water injected headers have a weep hole at the bottom of the bend by each exhaust port. This is an ignition source for any fumes in the engine compartment.
Your life and the life of others on board and around you is NOT worth a cheap set of headers.
Water injected headers should be used with a valve that cuts off the water flow below 1500-2000 rpm.
If you remove that valve and add water pressure you will get reversion on the first firing of the engine and destroy your engine in the first few minutes.
Jonas.
38KV is offline
Old 11-02-2004 | 06:50 AM
KNOT-RIGHT's Avatar
They look like these. I am in desperate need of one set of these.
Do you think your source would have a pair??? Bassetts
Dont mean to hijak your thread Thomas.
Attached Thumbnails Distance between headers-000_0011.jpg   Distance between headers-000_0013.jpg
KNOT-RIGHT is offline
Old 11-02-2004 | 07:40 AM
38KV's Avatar
caveman, They are exactly the same as mine!
This guy Jesper I bought them from is board member "Cigaretteman".
He is in Florida for the moment, send him a PM and ask.
Jonas
PS. I have his cell # if it's needed.
38KV is offline
Old 11-02-2004 | 07:08 PM
KNOT-RIGHT's Avatar
I have been searching for those headers for the last five years.
I even asked Paul Bassett to repair mine. I sent Jesper a pm
Thank you
Gerry
PS. I know its a shot in the dark..
Aqua Banshee
Classic Offshore
72
07-17-2015 04:45 AM
Velocity Vector
Velocity
2
07-11-2008 08:57 PM
Audiofn
3
02-19-2007 08:09 PM
Audiofn
2
03-18-2005 09:26 AM
